CSHEAR
Bulk Data Entry Defines a shear panel element.
CSHEAR EID PID G1 G2 G3 G4
CSHEAR 111 67 89 123 124 56
EID Unique element identification number.
(Integer > 0)
PID A PSHEAR property entry identification number.
(Integer > 0; If blank, defaults to EID)
G1, G2, G3, G4 Grid point identification numbers of connection points.
Grid points G1 through G4 must be ordered consecutively around the perimeter of the element.
(Integer > 0; all unique)
  1. All interior angles must be less than 180 degrees.
    Figure 1. CSHEAR Definition
    Figure 2. CSHEAR Element Corner Forces and Shear Flows
  2. Shear panel elements are ignored in heat transfer analysis.
  3. This card is represented as a quad4 element in HyperMesh.
