_des.h3d file
A compressed binary file, containing both model and result data. It can be used to post-process results in HyperView or when using the HyperView Player.
File Creation
The _des.h3d file is created when the H3D format is chosen (I/O Option OUTPUT), and an optimization run is performed.
File Contents
The _des.h3d file contains node and element definitions in addition to the following results.
Result
Density
Density results from topology optimizations.
Output is controlled by the I/O Option DENSRES.
Shape
Shape results from topography or shape optimizations.
Thickness
Thickness results from size and topology optimizations.
Material Type
Material type results from multiple material topology optimizations.
Output is controlled by the I/O Option DENSRES. 1
  1. The material type would be shown as 0, if the density of each material is less than 0.3.
