.#.#.dis.# file
The .#.#.dis.# file is a Patran 2.5 ASCII format results file
File Creation
This file is created when the Patran format is chosen and normal modes analyses are performed. (See documentation for the I/O Option OUTPUT).
File Contents
Result Description
Eigenvector Eigenvector results from normal modes analyses.
Output is controlled by the I/O Option DISPLACEMENT.
  1. One such file is created for each calculated mode at each iteration where the I/O Option RESULTS requests analytical results to be output.
  2. The first # in the file name is the user-defined Subcase ID.
  3. The second # in the file name is the mode number.
  4. The third # in the file name is the iteration number.
