DMIGROT
Bulk Data Entry Controls rotation and other specifications for a matrix entered using DMIG entry.
DMIGROT NAME G1     SCALE ITRAN
DMIGROT KAAO 128
NAME Name of the DMIG matrix for which the rotation is input.
No default (Character)
G1 Grid Identification number which defines the rotation of the DMIG.
No default (Integer)
SCALE Defines the scale factor by which each term of the DMIG matrix is scaled.
Default = 1.0 (Real)
ITRAN Controls whether the DMIG matrix is transformed.
0 (Default)
Not transformed.
1
Transformed using G1 to form the transformation matrix.
  1. Any DMIG matrix with the same name as specified on the NAME field will be rotated with G1.
