DOPTPRM, AUTOWGHT
Bulk Data Entry Option to automatically normalize the compliances in the WCOMP response, before applying the weight factors.
Parameter Values Description
AUTOWGHT <YES, NO> Used to automatically normalize the compliances in the WCOMP response with respect to their value at iteration 0, before applying the weight factors.
YES
NO (Default)
  1. The new weight factors calculated from the input weight factors and the compliances from iteration 0 will be used in the WCOMP response for all the iterations.
