DOPTPRM, MINDENS
Bulk Data Entry Sets the minimum element material density.
Parameter Values Description
MINDENS Real > 0.0
Default = 0.01
Sets a lower limit on the amount of material that can be assigned to any design element. Extremely low values for this parameter can result in an ill-conditioned stiffness matrix.
