DRESP1 - Frequency Response Stress/Strain Item Codes
Element Stress/Strain Item Component ASCII Code Number Code1
CELAS Stress/Strain Real R-S 2
Imaginary I-S 3
Magnitude M-S 2
Phase P-S 3
CROD Both ends Real R-SAB
Imaginary I-SAB
Magnitude M-SAB
Phase P-SAB
End A Real R-SA 2
Imaginary I-SA 3
Magnitude M-SA 2
Phase P-SA 3
End B Real R-SB
Imaginary I-SB
Magnitude M-SB
Phase P-SB
CBAR All Stresses/Strains Real R-SALL
Imaginary I-SALL
Magnitude M-SALL
Phase P-SALL
End A point C Real R-SAC 2
Imaginary I-SAC 7
Magnitude M-SAC 2
Phase P-SAC 7
End A point D Real R-SAD 3
Imaginary I-SAD 8
Magnitude M-SAD 3
Phase P-SAD 8
End A point E Real R-SAE 4
Imaginary I-SAE 9
Magnitude M-SAE 4
Phase P-SAE 9
End A point F Real R-SAF 5
Imaginary I-SAF 10
Magnitude M-SAF 5
Phase P-SAF 10
End B point C Real R-SBC 12
Imaginary I-SBC 16
Magnitude M-SBC 12
Phase P-SBC 16
End B point D Real R-SBD 13
Imaginary I-SBD 17
Magnitude M-SBD 13
Phase P-SBD 17
End B point E Real R-SBE 14
Imaginary I-SBE 18
Magnitude M-SBE 14
Phase P-SBE 18
End B point F Real R-SBF 15
Imaginary I-SBF 19
Magnitude M-SBF 15
Phase P-SBF 19
Maximum at end A Real R-SAMAX
Imaginary I-SAMAX
Magnitude M-SAMAX
Phase P-SAMAX
Maximum at end B Real R-SBMAX
Imaginary I-SBMAS
Magnitude M-SBMAX
Phase P-SBMAX
CBEAM All Stresses/Strains Real R-SALL
Imaginary I-SALL
Magnitude M-SALL
Phase P-SALL
End A point C Real R-SAC 4
Imaginary I-SAC 8
Magnitude M-SAC 4
Phase P-SAC 8
End A point D Real R-SAD 5
Imaginary I-SAD 9
Magnitude M-SAD 5
Phase P-SAD 9
End A point E Real R-SAE 6
Imaginary I-SAE 10
Magnitude M-SAE 6
Phase P-SAE 10
End A point F Real R-SAF 7
Imaginary I-SAF 11
Magnitude M-SAF 7
Phase P-SAF 11
End B point C Real R-SBC 104
Imaginary I-SBC 108
Magnitude M-SBC 104
Phase P-SBC 108
End B point D Real R-SBD 105
Imaginary I-SBD 109
Magnitude M-SBD 105
Phase P-SBD 109
End B point E Real R-SBE 106
Imaginary I-SBE 110
Magnitude M-SBE 106
Phase P-SBE 110
End B point F Real R-SBF 107
Imaginary I-SBF 111
Magnitude M-SBF 107
Phase P-SBF 111
Imaginary I-SAMAX
Magnitude M-SAMAX
Phase P-SAMAX
Imaginary I-SBMAX
Magnitude M-SBMAX
Phase P-SBMAX
CSHEAR Maximum Shear Real R-SHMAX 2
Imaginary I-SHMAX 3
Magnitude M-SHMAX 2
Phase P-SHMAX 3
Average Shear Real R-SHAVG 4
Imaginary I-SHAVG 5
Magnitude M-SHAVG 4
Phase P-SHAVG 5
All Solid Elements Normal X Real R-SXX 6
Imaginary I-SXX 12
Magnitude M-SXX 6
Phase P-SXX 12
Normal Y Real R-SYY 7
Imaginary I-SYY 13
Magnitude M-SYY 7
Phase P-SYY 13
Normal Z Real R-SZZ 8
Imaginary I-SZZ 14
Magnitude M-SZZ 8
Phase P-SZZ 14
Shear XY Real R-SXY 9
Imaginary I-SXY 15
Magnitude M-SXY 9
Phase P-SXY 15
Shear YZ Real R-SYZ 10
Imaginary I-SYZ 16
Magnitude M-SYZ 10
Phase P-SYZ 16
Shear XZ Real R-SXZ 11
Imaginary I-SXZ 17
Magnitude M-SXZ 11
Phase P-SXZ 17
von Mises - SVM -
Max Principal Stress - SMP -
All Shell Elements Normal X at both surfaces Real R-SXB
Imaginary I-SXB
Magnitude M-SXB
Phase P-SXB
Normal X at Z1 Real R-SX1 3
Imaginary I-SX1 4
Magnitude M-SX1 3
Phase P-SX1 4
Normal X at Z2 Real R-SX2 10
Imaginary I-SX2 11
Magnitude M-SX2 10
Phase P-SX2 11
Normal Y at both surfaces Real R-SYB
Imaginary I-SYB
Magnitude M-SYB
Phase P-SYB
Normal Y at Z1 Real R-SY1 5
Imaginary I-SY1 6
Magnitude M-SY1 5
Phase P-SY1 6
Normal Y at Z2 Real R-SY2 12
Imaginary I-SY2 13
Magnitude M-SY2 12
Phase P-SY2 13
Shear XY at both surfaces Real R-SXYB
Imaginary I-SXYB
Magnitude M-SXYB
Phase P-SXYB
Shear XY at Z1 Real R-SXY1 7
Imaginary I-SXY1 8
Magnitude M-SXY1 7
Phase P-SXY1 8
Shear XY at Z2 Real R-SXY2 14
Imaginary I-SXY2 15
Magnitude M-SXY2 14
Phase P-SXY2 15
von Mises at Z1 - SVM1 -
von Mises at Z2 - SVM2 -
von Mises - SVMB -
Major Principal Both Surfaces - SMPB -
Major Principal 1 - SMP1 -
Major Principal 2 - SMP2 -
1 OptiStruct provides partial support for Nastran item codes. Since Nastran response items are not fully compatible with those used in OptiStruct, it is recommended that the OptiStruct ASCII item codes be used.
