DVCREL - Types
Depending on the TYPE entry, the FID of the appropriate design parameter can be determined from the tables below.
Type Field 1 Field 2 Field 3 Field 4 Field 5 Field 6 Field 7 Field 8 Field 9 Field 10
CONM1 M11 M21 M22 M31 M32
FID 11-20 M33 M41 M42 M43 M44 M51 M52 M53
FID 21-30 M54 M55 M61 M62 M63 M64 M65 M66
CONM2   M X1 X2 X3
FID 11-20   I11 I21 I22 I31 I32 I33
CMASS2   M
CMASS4 M
CDAMP2   B
CDAMP   B
CBAR   X1 X2 X3
FID 11-20   W1A W2A W3A W1B W2B W3B
Type Field1 Field2 Field 3 Field4 Field5 Field6 Field7 Field8 Field9 Field10
CBEAM X1 X2 X3
CONROD   A J C NSM
CELAS2 K GE S
CELAS4 K GE S
CTRIA3 ZOFFS
        T (see Comment 1)
CTRIA6
FID 11-20 ZOFFS T (see Comment 1)
CQUAD4 T (see Comment 1) ZOFFS
CQUAD8
FID 11-20 T (see Comment 1) ZOFFS
  1. If the FID field of DVCREL1/2 is set to T, then the averaged nodal thickness is used as a design parameter for optimization. The CQUAD4, CTRIA3, CQUAD8, CTRIA6 elements are supported. There is no support for Nastran Item Codes for this parameter. Even though the averaged nodal thickness value is optimized, the actual nodal thicknesses are updated (while preserving the element aspect ratio). This is also written out into the .prop file.
