ELEMQUAL
Bulk Data Entry Resets the default values of the warning and error bound limits for element quality check.
ELEMQUAL | ETYPE | PTYPE | LTYPE | V1 | V2 |
Example 1
ELEMQUAL | TRIA3 | ARATIO | ERROR | 300.0 |
Example 2
ELEMQUAL | TETRA | COLLAPSE | WARNING | 0.01 | 10. |
ETYPE | Element type. Valid entries are:
No default |
PTYPE | Geometric property type. Valid entries are:
No default |
LTYPE | Bound limits type.
No default |
V1 | Lower bound value. No default (Real) |
V2 | Upper bound value. No default (Real) |
- Element quality checks and their default settings are described in the Element Quality Check section.
- All specified values (V1 and V2) are checked against the corresponding limits used for validity check. Data outside the validity range is ignored.
