ERPPNL
Bulk Data Entry Defines one or more sets of elements as panels for equivalent radiated power output for a frequency response analysis.
ERPPNL NAME1 SID1 NAME2 SID2 NAME3 SID3 NAME4 SID4
  NAME5 SID5 etc
NAME# Panel label.
No default (Character string)
SID# Set identification number for a set of elements.
No default (Integer > 0)
  1. The direction of normals of elements selected as a panel for ERP output should be consistent. OptiStruct will automatically flip normals of elements which have inconsistent normals if such elements belong to panels selected for ERP output.
