Exercise
In this tutorial, a control arm loaded by brake force and vertical force is used, as
shown in Figure 1. Two load time histories acquired for 2545 seconds with 1 HZ, shown in Figure 2 and Figure 3, are adopted. The material of the control arm is aluminum, whose E-N curve is
shown in Figure 4. Because a crack always initiates from the surface, a skin meshed with shell
elements is designed to cover the solid elements, which can improve the accuracy of
calculation as well.
The model being used for this exercise is that of a control arm as shown in Figure 1. Loads and boundary conditions and two static loadcases have already been defined on this model.
