FATPARM
Subcase Information Entry The FATPARM command can be used to select a FATPARM Bulk Data Entry that will define the parameters to be used for a Fatigue Analysis.
FATPARM = option
Argument Options Description
option <SID>
No default
SID
Set identification of a FATPARM Bulk Data Entry.
  1. FATPARM Bulk Data Entries will not be used unless selected in the Subcase Information section.
  2. If present above the first subcase, it is applied to all fatigue analysis subcases.
