FLDATA
Bulk Data Entry Defines a forming limit curve as a table of minor and major strain values in a one-step stamping simulation.
FLDATA FLDID Ei1 Ei2
FLDATA 2 -.194 .284
FLDATA 2 -.0.89 .269
FLDATA 2 etc etc
FLDATA 2 .319 .319
FLDID Blank holder identification number
No default (Integer > 0)
Ei1 Minor strain value
No default (Real)
Ei2 Major strain value
No default (Real)
  1. This entry is only valid with an @ HyperForm statement in the first line of the input file.
