OS-T: 1600 Fluid-Structure Interaction Analysis of Piezoelectric Harvester Assembly
The purpose of this tutorial is to demonstrate how to carry out Fluid-Structure Interaction analysis that is, with OptiStruct nonlinear transient analysis coupling within AcuSolve fluid dynamic analysis.
Figure 1. Schematic of the Problem
Figure 2. Various Layers of Beam
The AcuSolve fluid model (slab_dcfsi.inp) and the OptiStruct structural beam model (Slab.fem) are located in the fsi_models.zip file. Refer to Access the Model Files.
Launch HyperMesh and Set the OptiStruct User Profile
Import the Model
Set Up the Model
Create Contact Surface
Define Nonlinear Parameters
Define Transient Time Step Parameters
Define Incremental Result Output for Nonlinear Analysis
Define Fluid-Structure Interaction Parameters
Define Output Control Parameters
- From the Analysis page, select control cards.
- Click GLOBAL_OUTPUT_REQUEST.
- For DISPLACEMENT, ELFORCE, OLOAD, STRESS, and STRAIN, set Option to Yes.
- Click return twice to go to the main menu.
Create Nonlinear Transient Analysis Subcase
Submit the Job
Initiate a Run
Submit the AcuSolve Job
- cci.txt
- Contains information pertaining to model progression. Logs regarding connection establishment, initial external code handshake and subsequent time step data in conjunction with exchange/stagger.
- Slab.html
- HTML report of the analysis, giving a summary of the problem formulation and the analysis results.
- Slab.out
- ASCII based output file of the model check run before the simulation begins and gives some basic information on the results of the run.
- Slab.stat
- Summary of analysis process, providing CPU information for each step during the process.
- Slab.h3d
- HyperView compressed binary results file.
View the Results
Figure 14.
