FMETHOD
Subcase Information Entry Used to specify the parameters for aerodynamic flutter analysis, by referencing a FLUTTER Bulk Data Entry.
FMETHOD = option
Argument Options Description
option <ID>
ID
Identification number of a FLUTTER Bulk Data Entry.
No default (Integer > 0)
  1. This entry is required for a flutter analysis.
  2. The CMETHOD Subcase Information Entry must also be specified when K-method of flutter analysis is used.
