FREQ1
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, frequency increment, and the number of increments desired.
FREQ1 SID F1 DF NDF
FREQ1 6 2.9 0.5 13
SID Set identification number.
No default (Integer > 0)
F1 First frequency in set.
No default (Real ≥ 0)
DF Frequency increment.
No default (Real > 0.0)
NDF Number of frequency increments.
Default = 1 (Integer > 0)
  1. FREQ1 entries must be selected with the I/O Options or Subcase Information command FREQUENCY = SID.
  2. The units for F1 and DF are cycles per unit time.
  3. The frequencies defined by this entry are given by fi = F1 + DF * (i -1)
    where i = 1 to (NDF + 1).
  4. All FREQi entries with the same set identification numbers will be used. Duplicate frequencies will be ignored. f N and f N − 1 are considered duplicated if:(1)
    | f N − f N − 1 | < DFREQ * | f MAX − f MIN |
    Where,
    DFREQ
    User parameter with a default of 10-5 * f M A X
    f M I N
    The maximum and minimum excitation frequencies of the combined FREQi entries
  5. This card is represented as a load collector in HyperMesh.
