_gauge.h3d file
A compressed binary file containing both model and result data. It can be used to post-process shell thickness (gauge) sensitivity in HyperView.
File Creation
This file is created when an optimization is performed. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
The _gauge.h3d file contains node and element definitions in addition to the following results:
Result
Sensitivity
Sensitivity of response versus shell thickness (gauge) of PSHELL property.
Output is controlled by the I/O Option OUTPUT.
  1. A single _gauge.h3d file is created for all iterations.
