GRIDS
Bulk Data Entry Defines a grid point on the y-z plane, using cartesian coordinates, for use in the definition of arbitrary beam cross-sections.
GRIDS ID Y Z
GRIDS 101 1.1 2.1
ID Identification number.
No default (Integer > 0)
Y Y location of the grid point.
No default (Real)
Z Z location of the grid point.
No default (Real)
  1. All grid point identification numbers within a section definition must be unique with respect to all other grid point identification numbers within the same section definition.
  2. This entry is only valid when it appears between the BEGIN and END statements.
