.html file
The .html file is a HyperText Markup Language file.
File Creation
This file is always output.
File Contents
This file contains a problem summary and results summary of the run.
The problem summary contains information on the finite element model, subcase definitions, and optimization parameters.
The results summary lists the following results for an analysis or the final iteration of an optimization.
For linear static subcases:
  • The maximum displacement and the node where this occurs
  • The maximum strain energy density and the element where this occurs
  • The maximum stress and strain for 1D, 2D, and 3D elements and the elements where these occur
For normal modes subcases:
  • The frequencies of the calculated modes
  • The maximum deformation and the node where this occurs
For linear buckling subcases:
  • The buckling factor for the calculated modes
