MATT1EC
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT1EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
MATT1EC MID T( ρ ) T(JH)
MATT1EC 24 200
MID Material identification number of a MAT4 Bulk Data Entry that is temperature dependent.
No default (Integer > 0)
T( ρ ) Identification number of a TABLEMi or TABLEG entry that defines temperature-dependent electrical resistivity.
Default = 0 (Integer ≥ 0)
T(JH) Identification number of a TABLEMi or TABLEG entry that defines temperature-dependent Joule heating fraction.
  1. The quantities defined on the MAT1EC Bulk Data Entry are multiplied by the tabular function referenced by the MATT1EC Bulk Data card to generate the corresponding material properties.
  2. If the fields are blank or zero, constant properties defined on the MAT1EC Bulk Data card are used.
