MATT2EC
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT2EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
MATT2EC | MID | T( XX) | T( YY) | T( ZZ) | |||||
T(JH) |
MATT2EC | 24 | 200 | 110 | 150 | |||||
101 |
MID | Material identification number of a
MAT5 Bulk Data Entry that is temperature
dependent. No default (Integer > 0) |
T( ij) | Identification number of a
TABLEMi or TABLEG
entry that defines the individual elements of the
temperature-dependent electric conduction matrix, along each
direction. Default = 0 (Integer ≥ 0) |
T(JH) | Identification number of a
TABLEMi or TABLEG
entry that defines temperature-dependent Joule heating fraction.
- The quantities defined on the MAT2EC Bulk Data Entry are multiplied by the tabular function referenced by the MATT2EC Bulk Data card to generate the corresponding material properties.
- If the fields are blank or zero, constant properties defined on the MAT2EC Bulk Data card are used.
