MATX13
Bulk Data Entry Defines rigid material for geometric nonlinear analysis.
MATX13 MID
MAT1 102 10.0   0.495 6.0E-10
MATX13 102
MID Material ID of the associated MAT1. 1
No default (Integer > 0)
  1. The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
  2. MATX13 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
  3. This card is represented as a material in HyperMesh.
