OS-E: 0890 Maximum Bead Width Constrain for Topology Optimization of Oil Pan
Maximum bead width constraint is implemented to prevent the formation of large beads during topography optimization.
The Oil Pan is modeled using first order Quad and Tria elements.
Figure 1. FE Model with Loadcases and Loadstep
Model Files
The model file used in this example includes:
71_Oilpan_Max_bead_width.fem
Model Description
An oil pan which is constrained in all directions on the bolting locations and normal mode analysis is performed. Topology optimization with the MAXW updated in the design variable (DTPG) card to control the maximum bead width in the optimization.
Objective
Maximize the first normal mode frequency
Constrains
Maintain the beadfrac response within the range 0.5 to 0.8
Design Variables
Topography
Results
Figure 2. Shape Change without Max Bead Width Control
Figure 3. Shape Change with Max Bead Width Control
