MBCRV
Bulk Data Entry Specifies the data used to define a curve.
MBCRV CVID LINEAR
  X1 Y1 X2 Y2 etc etc Xn Yn
MBCRV 399
  1.0 1.1 2.0 0.0 3.0 14.2 4.0 19.9
  5.0 12.1
CVID Curve identification number.
No default (Integer > 0)
LINEAR Linear extrapolation is used to determine the curve data when the independent coordinate goes out of the range specified on the Xi fields.
If this field is blank, no extrapolation is applied and an ERROR is output when the independent coordinate goes out of range.
Default = blank
X1, X2, X3, ..., Xn Independent curve data.
No default (Real, X1 < X2 < X3 < ...)
Y1, Y2, Y3, ..., Yn Dependent curve data.
No default (Real)
  1. This card is represented as a curve in HyperMesh.
