MBCVCV
Bulk Data Entry Defines a Curve to Curve Constraint.
MBCVCV JID blank PCID1 G3 V1
  blank blank PCID2 G4 V2
MBCVCV 1 1 0 0
    2 0 1
JID Joint identification number.
No default (Integer > 0)
PCID1 Parametric curve (MBPCRV) identification number.
PCID2 Parametric curve (MBPCRV) identification number.
G3 This grid specifies the guess for the initial contact point on the first curve.
Although this parameter is optional, specifying it helps the solver in determining the initial contact point.
V1 Specifies the sliding velocity of the contact point relative to the part on which the curve is etched. V1 is positive when contact point is moving toward the start of the curve and vice-versa.
Default = 0.0 (Real)
G4 This grid specifies the guess for the initial contact point on the second curve.
V2 Specifies the sliding velocity of the contact point relative to the part on which the curve is etched. V2 is positive when contact point is moving toward the start of the curve and vice-versa.
