_mbd.h3d file
A compressed binary file containing both model and result data from a multibody dynamics analysis. It can be used to post-process results in HyperView.
File Creation
This file is created when a multibody dynamics subcase is executed.
File Contents
The _mbd.h3d file contains node and element definitions in addition to the following results:
Data
Displacement
Displacement results from static, frequency response, transient response, and multibody dynamics analyses.
Deformation > Displacement
Deformations (deflections) of flexible bodies from multibody dynamics analyses in the body reference frame.
Deformation > Rotation
Deformation (rotations) of flexible bodies from multibody dynamics analyses in the body reference frame.
Strain
Strain results of flexible bodies from a multibody dynamics analysis.
Stress
Stress results of flexible bodies from a multibody dynamics analysis.
  1. This file format is the most compressed animation output for multibody dynamics analyses. It generates the smallest files compared to other formats.
