_mbd.xml file
The _mbd.xml file is a MotionSolve .xml file from a multibody dynamics analysis.
File Creation
This file is created when a multibody dynamics subcase is executed.
File Contents
The file format is documented in the MotionSolve manual. The purpose is the communication between the OptiStruct core and the integrated MotionSolve. This file, together with the <BODY_NAME>.h3d files, forms a full representation of the multibody dynamics model which can be run separately in MotionSolve.
