MBLIN
Bulk Data Entry Defines the parameters for a multibody system linear analysis.
MBLIN ID TYPE ASCALE ENGYDST PID_IN PID_OUT NODAMP
MBLIN 99 EIGEN 1.0
ID Unique identification number.
(Integer > 0)
TYPE Linear analysis type.
EIGEN
STMAT
ASCALE Animation scale.
Default = 1.0 (Real > 0.0)
ENGYDST Specifies whether the modal kinetic energy distribution is written out to the solver log file and the *_linz.mrf output file.
NO (Default)
YES
PID_IN Specifies the plant input ID used for the B and D state matrices.
No default (Integer)
PID_OUT Specifies the plant output ID used for the C and D state matrices.
NODAMP Specifies whether the linearization solver disables damping from all force elements for the eigenvalue solution.
FALSE (Default)
TRUE
  1. For further information, refer to Parameters: Linear Static in the MotionSolve Reference Guide.
  2. This card is represented as a load collector in HyperMesh.
