MBMNT
Bulk Data Entry Defines a constant moment at a grid point by specifying a vector.
MBMNT SID G1 CID M G3/N1 N2 N3 G2
MBMNT 3 345   100.0 0.0 1.0 0.0
SID Load set identification number.
No default (Integer > 0)
G1 Grid point identification number where the action force is applied.
CID Coordinate system identification number. Blank or 0 infer the basic coordinate system.
Default = 0 (Integer ≥ 0, or blank)
M Moment magnitude.
No default (Real)
G3 Grid point identification number to optionally supply N1, N2, N3 in conjunction with G1.
(Integer > 0)
N1,N2,N3 Defines the direction of the force vector. At least one of the vector components must be non-zero.
Default = 0.0 (Real)
G2 Grid point identification number where the reaction force is applied. If blank or zero, the force is an action-only force.
Default = 0 (Integer ≥ 0)
  1. This card is represented as a moment load in HyperMesh.
