MBSFRC
Bulk Data Entry Defines a constant scalar load on two grid points.
MBSFRC SID G1 G2 F
MBSFRC 3 345 346 1.0
SID Load set identification number.
No default (Integer > 0)
G1 Grid point identification number.
G2 Grid point identification number.
F Value of load
(Real)
  1. MBSFRC applies a translational action-reaction force along the line of action defined by the line segment connecting G1 and G2.
  2. The action force is applied to G1 and the reaction force is applied to G2.
  3. Tensile force is positive.
