MBSFRCE
Bulk Data Entry Defines an expression scalar load on two grid points.
MBSFRCE SID G1 G2 EID
MBSFRCE 3 345 346 1
SID Load set identification number.
No default (Integer > 0)
G1 Grid point identification number.
G2 Grid point identification number.
EID Expression identification number of the MBVAR entry.
  1. MBSFRCE applies a translational action-reaction force along the line of action defined by the line segment connecting G1 and G2.
  2. The action force is applied to G1 and the reaction force is applied to G2.
  3. Tensile force is positive.
