MBSIMP
Bulk Data Entry Defines the simulation parameters for subsequent multibody simulation.
MBSIMP ID CTOL IDTOL
MBSIMP 99 0.001 1.0E-8
ID Unique identification number.
(Integer > 0)
CTOL Constraint tolerance.
Default = 1.0E-10 (Real > 0.0)
IDTOL Implicit differentiation tolerance.
Default = 1.0E-6 (Real > 0.0)
  1. This card is represented as a load collector in HyperMesh.
