MLOAD
Subcase Information Entry The MLOAD command can be used to select a Multibody load set to be applied in a Multibody problem.
MLOAD = option
Argument Options Description
option <SID>
No default
SID
Set identification of GRAV, MBFRC, MBFRCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, MBSMNTE, and MLOAD Bulk Data Entries.
  1. Only one MLOAD entry can be present for each subcase.
  2. This Subcase Information Entry is only valid when it appears in a Multibody subcase.
  3. If the SID referenced by the MLOAD Subcase Information Entry matches with the SID defined for an MLOAD Bulk Data Entry, the information on this entry alone is selected. However, if a MLOAD Bulk Data Entry does not have the referenced SID defined, any of the Multibody load entries: GRAV, MBFRC, MBFCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, or MBSMNTE which have this SID will be selected.
