.mnf file
The .mnf file is an ADAMS modal neutral file.
File Creation
This file is created when OUTPUT, ADAMSMNF is presented during flexible body generation.
File Contents
This file contains the flexible body models.
  1. If GPSTRESS output is requested in addition to OUTPUT,ADAMSMNF, nodal stress results will be written to this file.
  2. PARAM, GPSLOC can be used to control the output location of stresses for shells (top/bottom/middle).
  3. The output in the .mnf file is in double precision.
