MOTION
Bulk Data Entry Defines a multibody as a combination of motion sets defined via MOTNJ, MOTNJC, MOTNJE, MOTNG, MOTNGC, and MOTNGE.
MOTION SID M1 M2 M3 M4 M5 M6 M7
  M8 M9 etc
MOTION 3 31 34 35
SID Motion set identification number. Must be selected in the Subcase Information section (MOTION= SID), if they are to be applied.
(Integer > 0)
Mi Motion set identification numbers defined via entry typed enumerated above. The Mi must be unique.
(Integer > 0)
  1. This card is represented as a load collector in HyperMesh.
