MOTNJ
Bulk Data Entry Defines a constant joint motion.
MOTNJ SID JID MTYPE D DTYPE D0 V0
MOTNJ 3 345 TRANS 1.0 DIS
SID Load set identification number.
(Integer > 0)
JID Joint identification number.
(Integer > 0)
MTYPE TRANS or ROT, ignored for revolute and translational joints.
D Value of motion.
(Real)
DTYPE Motion data type.
DIS
VEL
ACC
blank
Means displacement motion
D0 Initial displacement if motion data is of type velocity or acceleration, ignored otherwise.
V0 Initial velocity, if motion data type is acceleration, ignored otherwise.
  1. Joint motion can only be applied to cylindrical joints (MTYPE = TRANS or ROT), revolute joints (MTYPE = ROT), and translational joints (MTYPE = TRANS).
  2. The MOTNJ Bulk Data Entry should be selected in the MOTION Subcase Information section, if it is to be included in the analysis.
