_nl.out file
An ASCII format results file which can be used for monitoring and debugging of nonlinear analysis.
File Creation
This file is always created for any nonlinear static or nonlinear transient run.
File Contents
This file provides detailed information regarding the nonlinear solution progress, and can be used to monitor nonlinear runs and if required, investigate and debug any non-convergent nonlinear runs, including in conjunction with the _nl.h3d file (refer to Runtime Monitoring for more information).
File Format
The file contains nonlinear solution parameters and solution progress information for each subcase within the model. The format for each such subcase is the same, and for each subcase, it can be considered as consisting of two sections, the header section and the main section. The header section, outlines the nonlinear control parameters and the subsequent main section consists of the nonlinear solution progress summary for the particular subcase of interest.
So for each subcase:
  • Header section (Nonlinear Control Parameters)
  • Main section (Nonlinear Iteration Summary)
The following sections illustrate examples of both the header and main sections, along with an explanation of each item within the sections.
Header Section (Nonlinear Control Parameters)
The first part of the header section contains a list of items based on the input on the NLPARM entry.
For nonlinear static analysis, the following values are printed.
  • Initial time increment
    Depending on the type of analysis, this is calculated based on corresponding fields on NLPARM, TSTEP, or TSTEPNL (for instance, DT on NLPARM can define the Initial time increment).
  • Subcase (local) time at the end of this subcase
    Depending on the type of analysis, this is calculated based on corresponding fields on NLPARM, TSTEP, or TSTEPNL (for instance, TTERM on NLPARM can define the subcase (local) termination time).
  • Total time at the start of this subcase and Total time at the end of this subcase
    Depends on model setup. For continued subcases, the total time adds up for subsequent subcases.
  • Maximum number of iterations
    MAXITER field on NLPARM
For nonlinear transient analysis, these time values are determined based on a combination of NLPARM and TSTEP, or TSTEPNL entries.
Convergence criteria:
  • Tolerance Disp. (EPSU): EPSU field on NLPARM
  • Tolerance Force (EPSP): EPSP field on NLPARM
  • Tolerance Work (EPSW): EPSW field on NLPARM
The Time increment adjustment parameters on the NLADAPT entry are self-explanatory and labeled appropriately in the _nl.out file.
Figure 3.
The Time increment adjustment factors are used in adaptive time-stepping. The labels below say “default for SMDISP” or “default for LGDISP” in this example. However, this label can change based on the time increment adjustment system for a particular model (for instance, if the Expert system is turned on).
For Small Displacement Nonlinear analysis:
Figure 4.
For Large Displacement Nonlinear analysis:
Figure 5.
When DIRECT parameter is set to YES on NLADAPT entry, then these values are still printed in the _nl.out file but fixed timestep is used for the analysis.
Note: Not all parameters in the header section above are applicable to Small Displacement Nonlinear Analysis.
Main Section (Nonlinear Iteration Summary)
Nonlinear Iteration Summary table for Nonlinear Analysis.
For each iteration, of an increment, of a particular subcase, the following example tables are printed.
Figure 6. Model with Contacts
Figure 7. Model with Element Distortion
Where,
Avg. U
Represents the average displacement of all grids for a particular iteration for a subcase
EUI
Represents the relative error in displacements
EPI
Represents the relative error in terms of load
EWI
Represents the relative error in terms of work
Refer to the Nonlinear Convergence Criteria section of Nonlinear Static Analysis in the User Guide for more information.
MaxEquiv Plststrn
Represents the maximum equivalent plastic strain
Gap and Contact Element Status
The columns are self-explanatory.
  • Table Row Items within each increment
    MAX FORCE
    Maximum external force of all degrees of freedom.
    MAX RESIDUAL FORCE
    Maximum difference between the internal force and external force of all degrees of freedom. This is the unbalanced load at this iteration.
    MAX DISPLACEMENT INCREMENT
    Maximum incremental translational displacement of all degrees of freedom. It includes the current and all previous displacement corrections for this particular increment. Its printed value is reset at the end of each increment.
    MAX DISPLACEMENT CORRECTION
    Maximum translational displacement correction per iteration of all degrees of freedom. It is the correction applied to the displacement for each particular iteration. Its value varies from iteration to iteration, depending on the amount of displacement correction to be applied.
    MAX ROTATION INCREMENT
    Maximum incremental rotation of all degrees of freedom. It includes the current and all previous rotation corrections for this particular increment. Its printed value is reset at the end of each increment.
    MAX ROTATION CORRECTION
    Maximum rotation correction per iteration of all degrees of freedom. It is the correction applied to the rotation for each particular iteration. Its value varies from iteration to iteration, depending on the amount of rotation correction to be applied.
    MAX PENETRATION ERROR
    This is only applicable to models which contain Contact. It is the maximum penetration error among all contact interfaces in the model. The name, ID, and associated node ID of the CONTACT INTERFACE of interest is also printed.
    MAX PRESSURE ERROR
    This is only applicable to models which contain Contact. It is the maximum pressure error among all contact interfaces in the model. The name, ID, and associated node ID of the CONTACT INTERFACE of interest is also printed.
  • Grids associated with Contact Change
    The total number grids associated with a changed contact status for this iteration is turned OFF by default. Its printing can be controlled via the CONTCHG field of the NLPRINT Bulk Data Entry.
    Grid sets of each of the below associated contact changes are also printed to the corresponding _nl.h3d file, if NLMON,DISP,ITER/INC Bulk/Subcase pair exists.
    CONTACT CHANGE OPEN-TO-CLOSE
    The number of grids associated with a changed contact status for this iteration from Open to Close are printed.
    CONTACT CHANGE CLOSE-TO-OPEN
    The number of grids associated with a changed contact status for this iteration from Close to Open are printed.
    CONTACT CHANGE STICK-TO-SLIP
    The number of grids associated with a changed contact status for this iteration from Stick to Slip are printed.
    CONTACT CHANGE SLIP-TO-STICK
    The number of grids associated with a changed contact status for this iteration from Slip to Stick are printed.
    ELEMENT DISTORTION (total #, print # elements)
    The total number of elements which are distorted at a particular iteration. The default number of elements printed is 10, and this can be controlled using the ELEMDIST field of the NLPRINT Bulk Data Entry.
Grid sets of each of the above distorted elements are printed to the corresponding _nl.h3d file, if NLMON,DISP,ITER/INC Bulk/Subcase pair exists.
