Output Files
OptiStruct generates a variety of output files depending on various factors affecting output.
The files generated are grouped into categories depending on their corresponding functions and listed below.
General Run and Troubleshooting Information
OptiStruct OUT file (.out)
This file provides a process commentary and log of the solution.
The OptiStruct OUT ASCII file is a general and specific run information and output results file generated after every OptiStruct run. The contents of the OUT file depends on the output factors. Since this is an ASCII file, its contents can be viewed on any simple Text Editor.
There is only one type of OUT file generated regardless of the factors controlling output from OptiStruct. Only the contents of the OUT file varies depending on the model and run process.
Output
The Output included in the OUT file varies depending on the output factors mentioned above. A comprehensive list of different output available in the OUT file is available in the corresponding file documentation shown below.
OUT File
File Documentation
General/Default OUT file
.out
The OUT file does not contain any model data unless the model data is echoed by you (ECHO entry). This file is not intended for further viewing in HyperView and HyperGraph. The ASCII output format and post-processing methods vary depending on the type of output/information included in the OUT file.
General Output Information
Hyper3D Binary File (.h3d)
A compressed binary file containing both model and output data. It can be utilized to post-process results in HyperView, HyperView Player, and HyperGraph.
There are multiple types of H3D files output depending on the factors controlling output from OptiStruct.
The availability of results sorted by Solution Sequence in H3D format is listed in the Results Output by OptiStruct page.
Output
The Output included in the H3D file varies depending on the output factors mentioned above. A comprehensive list of different output available in the H3D file is available in the corresponding file documentation shown below.
H3D File
File Documentation
General/Default H3D file
.h3d file
BYITER and Optimization
.#.h3d file
Design Optimization H3D
_des.h3d file
Multibody Dynamics H3D
_mbd.h3d file
Topology Sensitivity H3D
_topol.h3d file
Gauge Sensitivity H3D
_gauge.h3d file
Linear Static Optimization H3D
_s#.h3d file
Output2 File (.op2)
A binary file containing both model and output data. It can be utilized to post-process results in HyperView, HyperView Player, and HyperGraph.
There are multiple types of OP2 files output depending on the factors controlling output from OptiStruct.
The availability of results sorted by Solution Sequence in OP2 format is listed in the Results Output by OptiStruct page.
Output
The Output included in the OP2 file varies depending on the output factors mentioned above. A comprehensive list of different output available in the OP2 file is available in the corresponding file documentation shown below.
H3D File
File Documentation
.op2 file
Mass Matrix OP2 file
.m.op2 file
Stiffness Matrix OP2 file
.k.op2 file
HyperMesh Results File (.res)
An HyperMesh binary results file containing both model and output data. It can be utilized to post-process results in HyperMesh.
After the model is opened in HyperMesh, the .res file can be loaded as "Results" in HyperMesh via File > Load > Results and selecting the corresponding .res file.
pch_output_load_resullts
Figure 1. Loading .res file in HyperMesh
Then the Post-processing panel can be accessed to further post-process results within HyperMesh.
pch_output_post_process
There is only one single type of RES file available and it is the <filename>.res file.
The availability of results sorted by Solution Sequence in RES format is listed in the Results Output by OptiStruct page.
Output
The Output included in the RES file varies depending on the output factors mentioned above. A comprehensive list of different output available in the RES file is available in the corresponding file documentation.
H3D File
File Documentation
.res file
Nastran Punch File (.pch)
A general output results file generated after an OptiStruct run, if its creation is requested via various supported output requests. This file provides an ASCII compliment to the binary result files.
The contents of the PCH file depends on the output factors. Since this is an ASCII file, its contents can be viewed on any simple Text Editor. The PCH file can also be loaded into HyperGraph and the results can be viewed.
There is only one PCH file generated regardless of the factors controlling output from OptiStruct. Only the contents of the PCH file varies depending on the model and run process.
Output
The Output included in the PCH file varies depending on the output factors mentioned above. A comprehensive list of different output available in the PCH file is available in the corresponding file documentation.
PCH File
File Documentation
General/Default PCH file
.pch file
The PCH file does not contain any model data. This file is not intended for further viewing in HyperView. The ASCII output format and post-processing methods vary depending on the type of output/information included in the PCH file. Details regarding the contents of the PCH file can be accessed at the following locations:
Grid-based Results Element-based Results
Displacement Element Stress (.pch file)
Velocity
Acceleration
