PAERO1
Bulk Data Entry Defines properties for CAERO1 panels. This is used for Vortex Lattice Method (VLM) and Doublet Lattice Method (DLM) in subsonic aeroelastic analysis.
PAERO1 PID
PAERO1 3
PID Property identification number. This is to be referenced by a CAERO1 Bulk Data Entry.
No default (Integer > 0)
  1. For the current release of OptiStruct, only the PID field is supported for the PAERO1 entry. For any CAERO1 Bulk Data Entry, a PAERO1 reference should be provided and this PAERO1 entry can be left blank.
