PARAM, AMLSMAXR
Bulk Data Entry Used to determine singularities in the stiffness matrix for AMLS eigenvalue solver.
Parameter Values Description
AMLSMAXR <Real>
Default = 1.0e-8
PARAM, AMLSMAXR is used to determine singularities in the stiffness matrix.
If the value of AMLSMAXR is exceeded in the process of factoring a stiffness matrix, this indicates a singularity in K. If the mass of this degree-of-freedom is zero, there is a "massless mechanism"; an SPC is applied and a message is written to the .out file. If there is mass, then this is a mechanism which is treated as a rigid body mode and a message is written to the .out file.
Refer to AMLS (Automatic Multi-level Sub-structuring) Eigensolver in the User Guide for more details.
