PARAM, AMLSNCPU
Bulk Data Entry Used to define the number of CPUs to be used by the external AMLS eigenvalue solver.
Parameter Values Description
AMLSNCPU Integer ≥ 1
Default = 1
This parameter is used to define the number of CPUs to be used by the external AMLS eigenvalue solver.
Refer to AMLS (Automatic Multi-level Sub-structuring) Eigensolver in the User Guide for more details.
  1. OptiStruct and AMLS can be run with different allocations of processors. For example, OptiStruct can be run with 1 processor and AMLS with 4 processors in the same run.
  2. PARAM,AMLSNCPU is only valid when PARAM, AMLS is set to YES.
