PARAM, BEAMALT
Bulk Data Entry Used to activate an alternate formulation for CBAR and CBEAM elements.
Parameter Values Description
BEAMALT <YES, NO>
YES
NO (Default)
Default, when the parameter is not present in the deck.
The new formulation includes the following differences when compared to the traditional formulation:
Extension and Torsion
Linear interpolation of the extension and twist variables across the nodes is assumed.
Bending-shear
A complete Timoshenko/Mindlin formulation is used in the alternate formulation (the traditional formulation, for beam kinematics, the shape functions use Euler-Bernoulli formulation; and the shear-stiffness is only introduced when needed for the traditional formulation).
As part of the complete Timoshenko formulation
The new formulation also includes effects of rotary inertia.
  1. This parameter cannot be specified in the input deck without a value. OptiStruct will error out in this case.
