PARAM, BUSHTLMT
Bulk Data Entry Issues a WARNING when the stiffness value for translational components on the PBUSH entry exceeds the specified limit (BUSHTLMT).
Parameter Values Description
BUSHTLMT <Real Number > 0.0>
Default = 1E+07
This parameter is used to issue a WARNING when the stiffness value for translational components on the PBUSH entry exceeds the specified limit (BUSHTLMT).
  1. This check is overridden when PARAM, BUSHSTIF is used to control the maximum stiffness value.
