PARAM, CDITER
Bulk Data Entry Controls the activation of MPC-based Fast Contact Analysis.
Parameter Values Description
CDITER <Integer ≥ 0>
Default = 0
Controls the activation of MPC-based Fast Contact Analysis. It also specifies the maximum number of iterations allowed. If this parameter does not exist in the input deck (default), MPC-based Fast Contact is not activated.
