PARAM, CK3
Bulk Data Entry Specifies factors for the stiffness matrix produced by GENEL cards.
Parameter Values Description
CK3 <Real>
Default = 1.0
CK3 specifies factors for the stiffness matrix produced by GENEL cards. The total stiffness matrix is:
K jj = K jj y + CK 3 * K jj G
Where,
K jj G
The stiffness generated by all GENEL cards.
K jj y
The combination of the stiffness generated from structural element entries in the Bulk Data section and the stiffness generated by the Subcase Information command K2GG and scaled by PARAM,CK2.
