PARAM, CMSDIRM
Bulk Data Entry Allows flexible body generation when directional masses are defined in the input file.
Parameter Values Description
CMSDIRM <YES, NO> PARAM, CMSDIRM allows flexible body generation when directional masses are defined in the input file.
YES
The existence of directional mass will be allowed for flexbody generation runs. A warning will be issued for the ignored or approximated CMASS1, CMASS2, and CONM1.
NO (Default)
The run will be terminated with an ERROR if the input file contains directional mass definitions and flexible body generation is requested.
Refer to Flexible Body Generation in the User Guide.
