PARAM, CP2
Bulk Data Entry Scale factor for direct input load matrices.
Parameter Values Description
CP2 <Real>
Default = 1.0
CP2 specifies factors for the direct input load matrix. The total load matrix is:
P j = P j x + CP 2 * P j 2
Where,
P j 2
Is selected in the Subcase Information command P2G.
p j x
Is generated from the static load entries in the Bulk Data section.
