PARAM, CRTELEM
Bulk Data Entry Controls the printing of the “n” smallest element/nodal timesteps for Nonlinear Explicit Analysis.
Parameter Values Description
CRTELEM <Integer>
Default = 10
This parameter is used to control the printing of the “n” smallest element/nodal timesteps for Nonlinear Explicit Analysis.
  • The value “n” is defined by CRTELEM.
  • This printing is output to both the <filename>.out file and a new <filename>.HM.crtelem.cmf file.
  • This timestep information is printed by default and the number of timesteps printed can be controlled by PARAM,CRTELEM,#.
The following is printed to the .out file for a model when PARAM,CRTELEM,20 is:
20 smallest element/nodal timesteps
 Type              ID     Timestep
 Solid           1092   5.2667E-04
 Solid           1156   5.2667E-04
 Solid           1036   5.2667E-04
 Solid           1085   5.2667E-04
 Solid           1100   5.2667E-04
 Solid           1149   5.2667E-04
 Solid           1029   5.2667E-04
 Solid           1093   5.2667E-04
 Solid            964   5.3370E-04
 Solid           1028   5.3370E-04
 Solid            908   5.3371E-04
 Solid            972   5.3371E-04
 Solid           1284   5.3371E-04
 Solid           1220   5.3371E-04
 Solid           1228   5.3371E-04
 Solid           1164   5.3371E-04
 Solid           1021   5.3371E-04
 Solid            957   5.3371E-04
 Solid            965   5.3371E-04
 Solid            901   5.3371E-04
