PARAM, NLAFILE
Bulk Data Entry This parameter controls the output of animation files (A-File) in geometric nonlinear analysis.
Note: Obsolete parameter - use RADPRM, NLAFILE.
Parameter Values Description
NLAFILE <YES, NO> This parameter controls the output of animation files (A-File) in geometric nonlinear analysis.
YES
The animation files are retained after geometric nonlinear analysis.
NO (Default)
The animation files are removed after geometric nonlinear analysis.
