PARAM, MASSDMIG
Bulk Data Entry For static condensation with ASET of a static loadcase, the reduced stiffness matrix [k] and load vector {p} are created.
Parameter Values Description
MASSDMIG <YES, NO> For static condensation with ASET of a static loadcase, the reduced stiffness matrix [k] and load vector {p} are created.
YES
If the reduced mass matrix is desired.
NO (Default)
